ZR1 vs C6Z mods on zr1 ported snout 102mm TB intake 2.35 pulley cooling mods pump 93 mods on c6z heads cam intake exhaust first run 60 roll zr1 had passenger, c6z no passenger. also zr1 was pulling timing due to doing 4 back to back runs. second run 60 roll cooler temps, both with passengers. |
Good pulls! |
Nice runs man! Good battles... H/C C6Zs are tough to run against with LBO ZR1s and C7Zs..... You figure the HP is pretty close, maybe a little more for the ZR1, but the C6Z is 250lbs lighter.. Takes a good bit of power to make up that much weight. |
Originally Posted by ajrothm
(Post 19747967)
Nice runs man! Good battles... H/C C6Zs are tough to run against with LBO ZR1s and C7Zs..... You figure the HP is pretty close, maybe a little more for the ZR1, but the C6Z is 250lbs lighter.. Takes a good bit of power to make up that much weight. on pump its only on 16 degrees of timing, last night on e75 we had 22 but plan on putting more, just need to figure out the pumps. |
Originally Posted by StealthFRC
(Post 19747976)
yea, I'm looking forward to this car on e85. we started tuning for it last night. car pulls like an animal but gets lean up top. from some research it seems the zr1's pumps take a lot of tricking in hp tuners to maintain pressure, my tuner will figure it out and then me an the c6z can re run. on pump its only on 16 degrees of timing, last night on e75 we had 22 but plan on putting more, just need to figure out the pumps. Time to spend some money yo..... I just spent $2k for a fuel system for my 71' yesterday....I hated to but...can't be taking Ls because of no fuel... |
(Post 19747976)
yea, I'm looking forward to this car on e85. we started tuning for it last night. car pulls like an animal but gets lean up top. from some research it seems the zr1's pumps take a lot of tricking in hp tuners to maintain pressure, my tuner will figure it out and then me an the c6z can re run. on pump its only on 16 degrees of timing, last night on e75 we had 22 but plan on putting more, just need to figure out the pumps. |
(Post 19747980)
A stock ZR1 pump will not keep up on E85 at 650rwhp...... Time to spend some money yo..... I just spent $2k for a fuel system for my 71' yesterday....I hated to but...can't be taking Ls because of no fuel... car already has the 1300 injectors. |
Originally Posted by islander033
(Post 19747982)
Can you run a BAP? |
A BAP will help for sure. You can make 700-750 on a stock ZR1 fuel pump on gas but....E85, I seriously doubt you could hold 700 rwhp SAFELY... Time for that triple Fore...:cool: |
(Post 19747994)
(Post 19748001)
that blows, so much miss info everywhere. i do not want a fuel system in this car LOL. You could probably run E50 at 700 and get all the gains from E... but you have to mix and stay on top of that shit...PITA... I'd put a fuel system in it, put that 14% lower on it, full E85 and make 700-725 rwhp, bone stock/unopened engine...= Perfect combo. Also, you could put meth on it and probably run full E85 on the stock pump/BAP. On our C7Zs, we have to run dual nozzle meth just to run E50 at 650-700 rwhp...and even that's on the ragged edge. To keep it simple, put on the dual nozzle meth, run full E85 and stick with the upper only... I'd think you could make 650+ like that...and not spend $2k+ for a fuel system. |
(Post 19748007)
At least you already have the ID1300s....that saves you $1500... You could probably run E50 at 700 and get all the gains from E... but you have to mix and stay on top of that shit...PITA... I'd put a fuel system in it, put that 14% lower on it, full E85 and make 700-725 rwhp, bone stock/unopened engine...= Perfect combo. Also, you could put meth on it and probably run full E85 on the stock pump/BAP. On our C7Zs, we have to run dual nozzle meth just to run E50 at 650-700 rwhp...and even that's on the ragged edge. To keep it simple, put on the dual nozzle meth, run full E85 and stick with the upper only... I'd think you could make 650+ like that...and not spend $2k+ for a fuel system. |
The Fore systems are great as well as e85. Love that setup on my car. |
Cool runs. |
Good runs. |
Good runs |
Great runs! I love that Zr1! Z06's are roll race monsters |
Tight runs. Halltech CAI on the C7z wakes them up quite a bit. The ram air option was icing on the cake. C6z, ZR1’s and C7z’s are all badass. LS7 is just cooler in my book cause it is all motor. Would of been a lot cooler if the heads didn’t poop on themselves in stock form. I am am hoping this new hopped up LT4 that comes in the ZR1 will make it cheap to add fuel system for e85 compatibility. |
(Post 19748007)
At least you already have the ID1300s....that saves you $1500... You could probably run E50 at 700 and get all the gains from E... but you have to mix and stay on top of that shit...PITA... I'd put a fuel system in it, put that 14% lower on it, full E85 and make 700-725 rwhp, bone stock/unopened engine...= Perfect combo. Also, you could put meth on it and probably run full E85 on the stock pump/BAP. On our C7Zs, we have to run dual nozzle meth just to run E50 at 650-700 rwhp...and even that's on the ragged edge. To keep it simple, put on the dual nozzle meth, run full E85 and stick with the upper only... I'd think you could make 650+ like that...and not spend $2k+ for a fuel system. Fore system is the way to go! This video proves the biggest enemy of ZR1s and Vs is heat.. That is a strong running Z though |
1 Attachment(s) i bit the bullet and just ordered one. now to find time for install. the car ran so much better/cooler on e85 that i couldn't bring myself to keep it on pump long. Attachment 718612 |
© 2024 MH Sub I, LLC dba Internet Brands
