Mach 1 vs Cammed/Stalled LS1
#42
come get mopped bitchtits. I own you and my ls1 beast will own anything you ever drive. There i said it for jake.....
#45
#47
Damn dude, sounds like you've had a messed up life. No wonder you're such a dipshit. Lolololol
#49
#51
hey im willing to travel to see you kick the **** out of a few. building the house is still taking all of my time. i do have more parts for the glide on the way. one piece at a time.
i dont think i mentioned it, but the original 1967 PG pump is in perfect condition. i mic'd it and the pump gear has .004 clearance with NO wear on the plates.
after drilling it i can put new bushings and pump gears in. i am converting it to th400 stator support tube and input shaft. th400 converters are cheap and plentiful .i am using a 300m ringed input shaft. one step at a time.
im using a combination of sonnax and fti parts. im going to run a relatively low rpm stall. im going to let the turbo stall it. i may get the stall wrong, but who gets it right the first time.
