Lucille vs bad 4th generation camaro
had the chance to meet with ricky ( SoFla01SSLookinstok) for some fum runs super cool dudes , after we talked about for a bit we went at it . ricky wanted a 40 rolls and i asked for a 20 roll in total we did three 40 rolls and one 20 roll , the first 40 i forgot to shift with the paddle shift and hit the rev limiter the rest of the runs were clean with the third run being a bad *** run neck to neck run .
couple of the races via dash cam.
Sweet vid! That 18 is very impressive. He shot out like a bullet on the 20 roll. So as Gus beat me, this is the second fastest 5.0 I've ran. First 18 though. This car is done right. Great match up.
No prob. My best run was an 11.80 @ 122. Not positive on weight. We were talking about some scales. A good guess is 3500-3550? One day I'll get a number.
Cams, ported CJ, WR, manual
first run i hit rev limiter and the other runs i let off at 150 rear tires are vibrating and the car was waggling side to side i made the comment when i got out , the second to last run we were neck to neck to 150 then i let off . he actually got a 3/4 of a car ahead on the hit which i made up and we both stay next to each other to 150
has a decent amount of WR. Ftw purple full cobra jet setup full exhaust cai drag pack etc. steedas car has all that but on stock mani with gears and c85. It hit 128 in great air
with just E85 cai and drag pack I’ve been seeing low 120s from them
i would think swapped car would trap 126-128. I’m kinda surprised a 122 car was door to door. So much for the trap speed roll race rule I guess. That or soflo hasn’t given his car a proper flogging on a decent track it looks faster than 122
great runs ricky car definitely moves out , wouldn't be surprise if your car weights around 3450 but definitely those were some bad *** runs .
thank you Ricky , this is my first run vs a 4th generation camaro and man isn't your car built right and it sounds impressively beautiful , we probably see each other in pbir if you going as well thank you for coming down to run i can't get much runs down here with the local safe racers . lol
When I ran Gus I didn't have the EWP. New mod.
