FBO 6th Gen, stock converter in +500 DA. - Page 4 - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Street Racing & Kill Stories Basic Technical Questions & Advice
Old 09-25-2018, 08:12 PM
  #61
HioSSilver's Avatar
Originally Posted by OneSlowV View Post
All motor 5.0 cars for you guys cars with motor swaps to . Shaun has ran a 10.13 @133 in his s550 he does have intake only cams though .
https://docs.google.com/spreadsheets...hw5Ac/htmlview
so cam only coyotah slower than bolt on ones and slower than a cam only ls1. Sounds about right.
Originally Posted by BlkMach1 View Post
Well whatever you put in it its entirely up to you......but dont make false claims that you're a bolt on car. its a motor swapped, built trans, built rear with some fancy "nascar" gears. If cory had a Gen 2 or Gen 3 coyote motor in his S197 you'd be saying its motor swapped, because guess what??? It ******* is!
Yes my bone stock S550 just like it came out of the dealer ran a 13.0 at 109 with a 2.15 60ft...so what? You think Im supposed to be ashamed because of that? LOL Hiollary you's a fool.
yea it's a bolt on engine. Get over it. I have another one to. Bolt on ls6 would be faster in a vette.
so a 13sec stock 5br0. Sounds about right to me. Slower than a stock 5gen tho.
idk what it takes to put a gen2 coyotah in a s197 5br0 chassis. Maybe you can inform us. Yes a gen3 woukd be a swap. They are different enough with di and a ci change to warrent that and probably needing a harness to run 2 sets of injectors.
You know what a ls1 car needs to accept a ls6? Nothing......nothing at all other than the oil pan and pick up tube. I even ran it on the ls1 tune. #replacement
never ran it with the nascar gears. You know the fancy used ones that cost like $160 shipped. Not uncommon for hotrods to have upgraded transmissions....besides i guess you should call cory out on his complete trans swap at this point. You know....just to keep things fair.
hopefully i straightened this up a bit before you ruin prays thread with dumbass accusations.
Originally Posted by ohioborn80 View Post
8s for na 5.0 is fastest on list.wow
like 1sec off the fastest na ls......that's wow
HioSSilver is online now
Old 09-25-2018, 08:39 PM
  #62
BlkMach1's Avatar
Just as I expected yours is bolt on but coyote it’s a swap. Well I guess by that standard my car is bolt on too. Everything went on by bolts and easier than an engine swap. Good talk.
BlkMach1 is online now
Old 09-25-2018, 08:43 PM
  #63
HioSSilver's Avatar
Well I'm not saying the coyote couldn't be bolt on in that chassis. I only stated the difference in a swap vs a replacement. Since you don't work on cars i can see where you would struggle with the reasoning of it.
so....what's it take to put a gen2 coyotah where a gen1 is? You never answered.....you just cried.
i can tell you what it takes to put a ls7 where a ls1 was. It's a swap but a mild one......like very mild.
a new lt would be more involved.
Old 09-25-2018, 09:09 PM
  #64
UltraZLS1's Avatar
An s197 with 10 speed and gen 3. And Light weight reduction woukd fly
UltraZLS1 is online now
Old 09-25-2018, 09:13 PM
  #65
BlkMach1's Avatar
A local guy has already put a gen 3 in a gen 2 car. Lots of guys run Gen 2 motors in gen 1 cars if/when they hurt their motors. It’s no biggie.
If you were so badass and ls1 so good you should stuck to it and made it fast.
Old 09-25-2018, 09:54 PM
  #66
HioSSilver's Avatar
probably so.
A local guy hasnít already put a gen 3 in a gen 2 car. Lots of guys run Gen 2 motors in gen 1 cars if/when they hurt their motors. Itís no biggie.
well i did help a friend make his ls1 go 11.9 w/o headers. But phil hurt my ls1. Seems alot of you stay hurt over the ls6.
well what's it take to change a ge1 to gen2? I know people can do it....you could swap a diesel in it if you wanted.
Old 09-25-2018, 10:40 PM
  #67
BlkMach1's Avatar
Gen 2 motor longblock, reuse your gen 1 timing parts and cams.
Old 09-25-2018, 11:26 PM
  #68
HioSSilver's Avatar
Ok...so pretty significant changes. Not like putting a ls6 where a ls1 was. Which only required changing the oil pan and pick up tube so it fits the 4gen chassis.
Old 09-26-2018, 05:25 AM
  #69
BlkMach1's Avatar
Everything bro’s do is significant for you. Go back to your LS1 and go 10s on bolt ons. Like you expect out of bro’s.
Old 09-26-2018, 08:23 AM
  #70
HioSSilver's Avatar
From what I've seen it's not to be expected and still have much of a car around you for the "bro's"
but yea changing you cams and chains are pretty significant for ANY engine. Definitely not sealed then......lol
Old 09-26-2018, 08:34 AM
  #71
OneSlowV's Avatar
A swap is a swap donít matter what model ls family it is and cams and chain is easy to do .
OneSlowV is offline
Old 09-26-2018, 08:40 AM
  #72
BlkMach1's Avatar
You’re actually using less aggressive gen1 cams. Like I said put a stock sealed LS1 and go fast.
Old 09-26-2018, 09:01 AM
  #73
HioSSilver's Avatar
When one engine goes in place of another engine with no changes it's a replacement.
cams in a 5br0 is a pita. Heard many say that. On top of that now you're mixing and matching cams to different model engines. Be no different than a ls6 cam in a ls1....or a ls7 cam in a ls3.
Old 09-26-2018, 09:07 AM
  #74
islander033's Avatar
You mean engine swapped like yourself...
Internal mods too. None of the CrewNN can get on any bolt on list.
islander033 is offline
Old 09-26-2018, 10:26 AM
  #75
OneSlowV's Avatar
So when I buy a s197 and buy a gen 3 5.0 long block and bolts right in then itís not a swap then is it ? Just bolt in from your experience?
OneSlowV is offline
Old 09-26-2018, 03:32 PM
  #76
ohioborn80's Avatar
So put vette engine in body its replacement.
Put mustang engine in mustang it is a swap.
Hmmm.
ohioborn80 is offline
Old 09-26-2018, 03:34 PM
  #77
ohioborn80's Avatar
1sec of 1sec off h/c cars? Of wait you mean those na cars that are fully built short blocks like hammA. With 500cu in engines. Lol
Old 09-26-2018, 03:46 PM
  #78
Chris25's Avatar
Hmmm.
Wasn't it like 25% or something that came with the LS6 block in 02 ? I know that those blocks didn't come with the 243 heads but still.
Chris25 is online now
Old 09-26-2018, 03:59 PM
  #79
big hammer's Avatar
ls been 7ís Na
big hammer is offline
Old 09-26-2018, 04:13 PM
  #80
Mike Morris's Avatar
I have seen some stock 02s with LS6 blocks. Its worth a tad more power but weaker.
Mike Morris is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
