TT Flop Gen 1LE vs 6th Gen ZL1 1LE
#201
7 Second Club
#203
Me too. What a clusterfuck,service bulletin and recall nightmare. And where does all that damn oil go??? What is so weird is I have read,known guys with last year of production ones and they never had any problems with theirs. Shame because prior motor was awesome and 6.4 was another POS,
I've had nothing but bad luck with diesels. My 6.0L had complete service records, all motorcraft parts, and 170K on it when I got it. Then the EGR cooler hose started leaking, the rear seal blew out of the HPOP, the turbo crapped out, the downpipe broke, the lift pump died, the injectors died, the new injectors died, the FICM died, the IPR and ICP died, the alternator died, it ate batteries like candy, and the stupid plastic radiator hose splitter broke. It would randomly refuse to start while hot, and had absolutely no power in 1st gear, only to slam 2nd and haul *****.
My dad's company had a 6.0L powerstroke. FICM and HPOP died. My brother in law had a 6.7L F250 platinum, the PCM died at 47K miles, he also had a 6.7L cummins fry the PCM. My 6.5L detroit was the most reliable, but it couldn't pull ****, overheated like a mother ****** until I upgraded the entire cooling system, and had wiring issues. Now you see why I prefer big block gas, at least the sum bitch starts.
#204
6br0 diesels are poop. 6.4 sucked. Actually idk why people bought furd trucks up to about 2011. They were a pos up till then. 5.4 was gutless wonder junk in the f250 and only marginally better in the f150. A 4.6ux truck wasn't even worth owning....actually had a guy complaining how gutless his was to me at my yardsale the other week. Just outta the blue. If you were on any rv forum guys would ask how to increase power for towing with that junk and the furd guys would chime in softly and say "there's nothing you can do for it". It really took a brand loyal moron to buy that ****.
#205
Like i said on your 5.0 vs 6.2 comparison. One look at the tq curve and it's easy to see which does better. It's also why the 3.5 ecoboost does well.
#208
I've got 160k on mine with no issues yet. It's worked daily in the oilfield too. Only things that have been replaced are wear items. Batteries, brakes, etc. I'm getting a new one in a week or so though.
#211
I'm torn between the OBS Ford and Chevy trucks. I prefer the looks, seats, and gas drivetrain in the Chevy, but I prefer the Ford's ride, brakes, turn radius, and wing windows.
#212
7 Second Club
Real world, same distance and same load numerous times proves my point. My 5.0 was slightly cheaper to pull with than my 6.2 was.
Your ricer calcs need not apply....
#213
So 2x what a 6.0 oil filter is and you still failed to address the fuel filter. 10qts of oil at a minimum of $3 a quart for cheap **** puts you at $42.50. So unless you're on some dealer special there is no way to make a oil change not be more expensive than a gas 6.0.......unless 10qts are cheaper than 6. Also some of these diesels since we are talking diesels in general here hold more oil than the duramax.
real world tq > you.
#214
7 Second Club
You so dum. I've said more, just not substantially more.
But I guess it's expensive if you don't have a job, but have a booming business?
#215
I work....don't know what you issue or concern you have with it.
that Canadian exchange rate must be better than we thought for a oil change on a diesel to cost less there than it does here. Only the dum ones wouldn't pick up on that.
#216
7 Second Club
Here's a pro tip--- you don't change fuel filter every oil change either. Dum Dum.
I'm not convinced you can even comprehend at a grade 7 level. You ain't bright....like at all. wow
#219
7 Second Club
3L per oil change is substantial if you can't afford it I guess. Hope Hiollary gets a job soon so she can afford some maintenance.
Maybe a gofundme page for her is in order....
#220
7.3l powerstroke here 260k miles only ever had the banks powerchip go bad. Tow a 34 foot fifthwheel up to the 5500 elevation ski area almost every weekend at one point. From 32 foot boats to car trailers and etc never had a problem going the speed limit and got around 12-14mpg from sea level too ski area. Now dont get me started on the fcking turning radius or uncomfy seats though jesus. Always loved my dads friends 2005 duallie duramax with the allison felt like driving a car almost.
