6th gen in mexico.
Just for something new. I'll post this for Buster as I don't think he comes here too often.
https://youtu.be/xjym-XU-jYI
Originally Posted by HioSSilver
It sounds like Jose short shifting on the 3/4 to me.
other than that he needs to get that ******* almost 70lb stock clutch out of that thing so it can accelerate.
Jose performed really good. Shame he couldn’t have his front skinnies with a legit front runner on for these races. Bro is CJ, C85 with good amount of weight reduction.
No.....they do it to help control the massive tq.
ex1- 4cyl hondas have about a 30lb clutch stock.
ex2- mustangs have about a 40lb clutch stock
I don't see anyone complaining about drivability in either of those vehicles with much much less off idle power available.
Now the argument could be made for nvh improvements. But from my experience of setting up my own very light clutch and us putting the same set up in a 5gen/c6 that's bogus to.
Lots of things control drivability of a clutch. The material it's made of, length of the clutch pedal assembly, fulcrum of clutch vs master, size of master, hydraulic release bearing face/diameter, weight to some extent w/o being absurdly heavy, the engine idle tune .....and probably a couple other things.
edit: gear ratio to
edit: gear ratio to
Yes and no. The initial hit of the stored energy yes.....but they likely pull timing and/or throttle position to control that. Why do you thing they advertise nls? It's not to make it faster......it's because they control the tq by managing the shift and thus reliability. W/o slipping the clutch into the next gear or controlling the inertia from it that heavy *** clutch is only holding the engine back.
