Ws6 vs 6th Gen camaro SS
On my way to work this morning a 6th gen camaro SS pulled up and claimed he was stock we did a 40roll up to about 90 and shut it down oddly he hung in pretty close to me about half a car behind me.. My car has a ls6 block, 243 heads, FAST 102, SNS stage 3 cam, Built 4L60e, ls3 injectors, ported oil pump, tsp UD pulley, ls2 timing chain, PTC 3600 stalled auto, Strange rearend and 93 octane tune... Does something seem off here?
On my way to work this morning a 6th gen camaro SS pulled up and claimed he was stock we did a 40roll up to about 90 and shut it down oddly he hung in pretty close to me about half a car behind me.. My car has a ls6 block, 243 heads, FAST 102, SNS stage 3 cam, ls3 injectors, ported oil pump, tsp UD pulley, ls2 timing chain, PTC 3600 stalled auto and 93 octane tune... Does something seem off here?
You should be spinning that combo to at least 7000 rpms and a 4000+ stall converter would be more ideal.
Imo your setup should have had a somewhat steady pull the whole race..... multiple car lengths
I agree with 98.....you should out run a stock 6gen pretty good if all is right with your car. But that was a short pull. Even a minute hit advantage can squash a pull on a 50mph delta.
The following users liked this post:
S8ER95Z (06-24-2021)
My t/a does roll to 7k. Question as to why you say 4k stall over 3600. Another question this is my first auto car ive owned is it better to keep it in drive and let it do the shifting for you or manually shift the a4 reason i ask is because if im doing rolls if i manually drop it car is already above the 3600 stall so it hits instantly
Car runs strong as hell but when i bought the car it had a speed density race fuel tune which they had to install Hi flow cats to sell it to me which required a new tune and i just did a 93. Wonder if shop did a **** *** job on the new tune
Imo if you want absolute ideal performance I would recommend a PT 4400 converter. I run a similar setup, a bit more aggressive all around, and the Pt4400 is a roll monster.
Here is a clip of mine. I spin it to 7200 and you can see how nice the shift extensions are, only dropping to around 63-6400 rpms keeping me in my power band constantly with my setup peaking around 68-6900 rpms.
A higher stall will help a lot with your shift extensions. I would guess your setup peaks around 66-6700 rpms.
https://youtu.be/7cYawJ2AIXQ
I just feel like if im on the highway and someone pulls up on me cruising at 60mph if i hit it the car is already in OD so it has to drop which is like a 2-3sec lag time then it hits hard, Should i manually drop to 2nd gear and just shift it myself or would a larger stall fix this?
Are you manually shifting the a4 or just keeping it in drive?
Then the second I go wot I bump it up a gear and let the transmission shift on its own.
Just be careful and try not to do a ton of higher rpm 2-1 manuel downshift for its very hard on the low roller sprag which is only engaged in 1st gear.
I manually drop it down but speed match the rpms. So if you think it's going to jump to 4000 rpms on the manual downshift, give it more gas as you're downshifting.
As you are pulling the shift lever down into second, give it more gas to approximately where you think it would be.
So say you think you're going to be at 5000 rpms after the manuel downshift, give it more gas at the same time to bring the motor rpms up to match.
I got my *** handed to me by a brand new lt1 6th gen...still with window registration sticker and dealer plates. My mods are
Ls6 top end (hand ported heads)
summit 8715 cam
3:73 gears
Full exhaust
stock tc
summit 8715 cam
3:73 gears
Full exhaust
stock tc
Like to see one try that with me..
