Strut Tower Bar Connected To Engine OK?
Not any modification to the body. Start with a cheap strut bar that's made for the car (luckily it comes with one stock), and just build a custom bar that attaches to the baseplates, and it'll bolt right up like any other bar.
Not necessarily, Lee. The motor plates that I'm familiar with, through a couple of oval track cars I was involved with, either mounted between the water pump and accessory holes on the front of the block, and/or the block/bellhousing in the rear of the engine. These plates then bolted to tabs which attached to the frame. Both cars, I should note, were fabricated steel chassied cars.
