Tunnel/Body Mount Torque Arm and Rear End Noise
Old 10-19-2008, 10:50 AM
97pontta's Avatar
Default Tunnel/Body Mount Torque Arm and Rear End Noise
How much does the body/tunnel mount torque arm transmit/amplify rear end noise, such as gear whine, compared to a trans mount torque arm?
I've had a body mount torque arm that mounts where the g-load brace and subframe connecters meet for the past 3 years. When I first installed the torque arm it was with the stock 10 bolt rear, I later upgraded to a Moser 9 inch rear using the same torque arm. When I installed the rear I had horrible gear whine, so loud that you could not have a reasonable conversation with your passenger. I talked with Moser and they told me it is common with the larger diameter gears. Not able to stand the noise any longer I had a local shop with a great reputation setup another set of gears about a year later hoping the gear whine would go away. Still had the exact same gear whine so I just accepted it for the past few years, but have not driven the car much.
Recently I have made up my mind that I need to resolve the noise and started looking at the suspension as a possible cause for the excessive noise. I have tubular LCAs, panhard rod, sub-frame connectors and torque arm.
I am tempted to mount the stock torque arm to the trans/OEM mount just for a test to se if it eliminates some of the issues. Had any one else had and issue with the body/tunnel mount torque arms and rear gear noise?
Old 10-21-2008, 07:07 AM
97pontta's Avatar
No one has tried both the trans mount and tunnel mount torque arm?
Old 10-21-2008, 07:49 AM
allmotor's Avatar
what ratio gear?
Old 10-21-2008, 09:16 AM
UMI Performance's Avatar
The Moser 9" doesn't like negative pinion angle on the street... check your pinion angle and try it at 0 degree's if you haven't already.
FWIW I run a tunnel mounted torque arm with a S60 and no additional road noise of whine.
Hope that helps!
Ryan
Old 10-21-2008, 12:24 PM
97pontta's Avatar
Running a 3.89 ratio. I've double checked the pinion angle and made sure it was set at 0 degree. Just got back from a test drive and still sounds the same. I just want to rule out the suspension as my problem before I have the rear gears setup again. I'm thinking about a different gear ratio, I've heard that 3.89 gears in the 9 inch can be noise, but that may just be bad info I've gotten. Thanks for the help guys.
Old 10-21-2008, 02:05 PM
allmotor's Avatar
Some gears make noise. Depends on ratio plus brand. Some brands make less noise than others. I have 4.10s in a moser 12 bolt and it whines as well. It depends more on how the gears are installed more than pinion angle being off by 1-2 degrees. Steeper gears like what we are using tend to whine.
Old 10-21-2008, 06:26 PM
SOMbitch's Avatar
You are not the first I heard complain about the Moser whine. I think it is inherent in many of those rearends. Look around or search it in rearend section.
Old 10-21-2008, 11:28 PM
97pontta's Avatar
How loud is the whine your talking about? I have long tube headers, Off road Y pipe and hooker catback. At speeds 35MPH plus I cannot hear my exhaust until I'm above 3500 RPM, and my exhaust isn't quiet. When I'm slowing on an off ramp for example it sounds like a jet landing, and I can hear gear noise at speeds as low as 10MPH. Its hard to have a conversation with someone in the car at hwy speeds without raising your voice. I can totally understand a little noise due to the larger diameter gears and ratio but I was always under the impression it was slightly noticeable.
Thanks again for the help guys.
Old 10-22-2008, 06:56 AM
allmotor's Avatar
I've had a few different brands of 4.10's in a couple different rearends and all of them have whined somewhat. I'm used to it now since its been a long time, but used to people would go for a ride in my car that don't know hardly anything about cars and be like wtf is that noise? I just got used to it over time. I have found royal purple 75 90 gear oil to help w the whine.
Old 10-22-2008, 10:45 AM
97pontta's Avatar
I think I may look at installing some sound dampening material under the interior carpet to help keep the noise down, maybe look at a different gear ratio.
Old 10-23-2008, 09:13 AM
jwastedx's Avatar
I have a Moser 9 Inch with 370 gears and it whines badly also. I have decided to get some sound deading material to put in and see if it helps.
Old 10-23-2008, 11:02 AM
97pontta's Avatar
Post up your results when you get it done. I plan on doing mine but it won't be until I park the car for the winter.
Old 10-23-2008, 10:20 PM
Phynix's Avatar
I have 4.30s in a 12 bolt moser, true trac dif, bmr extreme torque arm, race only lcas w/ relocation, rodded end panhard w/ relocation, no whine from the diff, some noise from the rodded end parts, but no whine
Old 10-26-2008, 02:05 PM
CW00BlackTA's Avatar
I have a Moser 9 inch with a Spohn body mounted TA. The first thing you need to do is get your gears re-set until they stop whining. It took me three tries to get it right in mine--but was well worth it (this was a local pro doing the work). I have 4.11s but can't hear them at all unless the stereo is off and I'm driving easy. The body mount TA will transmit more noise and vibration as you know. I bought longer mounting bolts and added some rubber pads between the mount and body. It helps. The main thing is to get your gears set right.
Old 10-26-2008, 02:16 PM
INMY01TA's Avatar
I have a Strange 12 bolt that whines pretty good. I had a body mounted torque arm a couple years ago, this amplified it.
Quick Reply: Tunnel/Body Mount Torque Arm and Rear End Noise
