Drag brakes
Drag brakes
ok i'm wanting to lighten the camaro up some more i did a search but didn't find anything
i want the strange front and rear drag brakes but what else is needed ???
and is there a good streetable lightened spindle for f bodes ???
i'd be thankfull for any help thats offered thanks
You'll need new braided lines and possibly a bearing spacer for your rear-end. We can supply everything you'd need.
http://www.sjmmanufacturing.com/cam_brk_ls1.html Click Strange drag brakes link on the left side.
So are those brakes good for street use or drag only? If they are good for the street I'd be interested also. Thanks for the link Steve, I liked checking out the line lock and ABS delete, I've been looking for both!
It depends on your definition of street use. They are drag brakes; they will remove ~60lbs from the front and ~25lbs from the rear-end. They will allow you for example to run our lightest wheels and our wheel setups that are less expensive than LS1 designed wheels.
They stop very well. They will not dissipate heat like your stock brakes. So they will not handle harsh repeated stops without seeing brake fade. They should work fine for someone that is just driving the car to car shows or light normal driving on the street.
sounds good to me though i mean what little bit i do drive on the car i don't tail people and usually just creap around so they will be fine i think and i'll duct them some air from the front to help cool them thanks man i'm tring to get this thing light light
