Mother F-ing tq arm mount!!!
Old 12-17-2008, 02:55 PM
99FormulaM6's Avatar
Default Mother F-ing tq arm mount!!!
Am I cursed or something?
I bought this 00 Firehawk a few weeks ago, and it has a vibration when taking off from a stop but it will go away if you slip the clutch just right. Well, my old Formula had the same problem and it was the tq arm mount.
So, i bought a poly bushing to replace the stock one, and when I went to take off the stock clamshell, it is welded shut.... I dont know why, but it is.
So I put up a wanted thread for a stock tq arm mount, and bought it from Beaflag VonRathburg. Well I go to put it on today, and its not the same mount as mine.
Do different year cars have different mounts? Or im thinking it might be from an A4 car or something...do they have different mounts?
Pics:
Mine-
One I bought-
Side by Side-
Old 12-17-2008, 04:19 PM
Blazingz28's Avatar
I would think that a4 and m6 have different mounting points... It is on the rear of the a4 trans,
but im not sure
Old 12-17-2008, 05:19 PM
01CaMMMaro's Avatar
yes the A4 and M6 mounts are different.
Old 12-17-2008, 05:30 PM
thats what i thought... i guess i shouldve specified when i bought it..
Old 12-19-2008, 06:58 PM
anyone know the part number for a t56 torque arm mount? or have one lying around?
Old 12-19-2008, 07:02 PM
jsteele90's Avatar
why the **** would someone weld it shut
Old 12-19-2008, 07:12 PM
i have no clue.lol. its the stock rubber bushing too, so its not like it was a poly bushing and someone couldnt get it to shut enough to thread the mounting bolts
Old 12-19-2008, 07:30 PM
MUSTANGBRKR02's Avatar
i think i have one in the garage.
Old 12-19-2008, 08:15 PM
please check....lol.
Old 12-19-2008, 08:30 PM
kidcamaro98's Avatar
I have one sitting on my car...when I put on my Spohn torque arm, I just slid the stocker out of the mount and its still bolted up to my car lol
how much do they go for??
Old 12-19-2008, 09:29 PM
9000th01ss's Avatar
That welded up one isn't right either. It should have a long bolt welded to it too.
Did the old one have three bolts holding it on?
I really don't think they are different, between the m6 and a4.
Old 12-19-2008, 09:32 PM
2002_Z28_Six_Speed's Avatar
grind off where it is welded and reweld it.
Old 12-20-2008, 07:45 AM
I paid 11 bucks shipped for the one that doesnt fit
the old one only had the one short bolt on it, i think it used to be long and was cut...
i only have a dremel and i started to grind it with that, but the bead is so thick it would take forever
Old 12-23-2008, 06:29 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'm sorry that one didn't work. I just found this because I searched my name. I can't use my most recent topics on this computer (because it sucks ***) and this thread came up. I didn't know they were different or if they were which one you needed. Let me look around my friend's shop for a 6 speed one. If I find one I will ship it to you for free. The other one I have is off of another automatic so that wouldn't help you.
Old 12-23-2008, 06:50 PM
That would be great! I honestly didnt even think to specify a4 or m6 which is why i never contacted you about it.
Old 12-23-2008, 07:01 PM
Manic Mechanic's Avatar
If you've ever had to replace a torque mount because your arm busted out of the POS you'd understand WTF someone welded that one up. They shortened the bolt to make it serviceable with the transmission still up in the tunnel, otherwise you have to drop the transmission down far enough to slide that long bolt out. You can probably use that one if you want.
Vernon
Old 12-23-2008, 07:15 PM
well there was only one bolt besides that short bolt holding the mount to the tranny. The bushing itself doesnt look too bad. I think the vibration might be the mount not being fully secured because it didnt have all the bolts...but now i have a new bushing and want to just replace it.
Old 12-23-2008, 07:19 PM
I don't blame you, I wouldn't skimp on the fasteners either.
Vernon
Old 12-30-2008, 08:09 AM
How much work is it to drop the tranny enough? I mean, I have taken trannys out for clutch swaps...but do I need to drop the whole damn thing for this stupid mount?
Old 12-30-2008, 08:42 AM
the_merv's Avatar
^^Once you unbolt the Cross Member and let it drop, you should have enough room.
Quick Reply: Mother F-ing tq arm mount!!!
