hotchkis STB install
ya its fairly easy man. the 2 shims go under the brackets for the shock towers. bolt down the brackets first, then the center bar
Moderator
I never got any shims (bought used) and never even
noticed.
It will go easier if you disassemble, put the "feet" in
place with the nuts barely onto the studs and pilot
the cross-bolts in with a fat Phillips screwdriver and
then dog down the nuts.
The first time I put it on was some work, but the
car seems to have "taken a set" to it now.
noticed.
