SJM ABS delete kicking my ass
SJM ABS delete kicking my ***
Ok guys, I am installing the SJM ABS delete kit right now. I am trying to make the double flares and they are kicking my ***. The very first one I did looks pretty good and I think will work but now all the others keep coming out lopsided or the tube keep slipping in the flare holder. I left the braided steel line so I don't have much brake line to work with. Anybody have any tips to these damn double flares and what I am doing wrong? Part of the problem may be that the line is all bent from the factory so I don't know that its fitting in the holder right. Can I bend these lines back straight with a tubing bender or will they break? Any ideas? Please help!!
Moderator
I never was able to double-flare using cheapo flare
tools, there are some good ones that I guess do a
better job of holding the work. Don't remember the
brands.
Maybe you want an assortment of short lengths
already flared, mock it up and go shopping? A penny
saved is a busted knuckle earned, etc.
brands.
I had real hard time flaring the stock lines as well, sounds exactly like the problems i was having. The lines supplied in the kit flare extremely easy compared to stock. I got so fustrated i pulled out the lines and took them to a shop to flare for me.
I cranked the tool down with pliers, then I sprayed WD40 on the first die, then sprayed it on the final flare tool also, sounds stupid but it helps, straighten the lines out as good as you can, I clamped the line in the tool, just before the bends, and slowly straighten them out, If you have a slight bend on the end, put it (end) in the tool crank it down it will also straighten it, having the ends straight is important, it determans if the flare it self remains straight, Also on the final flare dont crank it down super hard, I found out that if I did this it allowed for it to seat better on the brass fitting. Also a good quality flaring tool is important. I have a LISLE brand I bought 20 years ago and works perfect everytime. I just finished one of his kits up last night.
Our flaring kit is modified before it gets to the end user so that it works well with the stock lines. You can use a SAE tool...but there is a greater chance of line slipping if you're not careful.
tording99Z28, let me know the final results.
Thanks steve. I will give you a call if I still can't get it. I am going to try and put some vice grips on the wing nuts to really tighten the flaring clamp down on the line so it doesn't move. The first one I did looks pretty good and I think will seal but the next one I have tried twice and both times it has gone lopsided on me and keep pushing the line out of the holder. I did everything exactly the same as the first, the way we talked about on the phone. The only thing I am going to try is get a tube cutter to cut the line so its a nice even 90 degree cut. I am curious if I am getting the end of the tube square enough with my file and puting the line in the holding tool and filing it down flush with the tool.
I'd advise not using a tube cutter.
Especially older ones which can be dull. What you'll end up doing is shrinking the tube diameter due to the roller die's as you spin and tighten the tube cutter. Once the line slips in a flaring bar, its difficult to make it stop without either clamping it as you mentioned or literally cutting the 1/2" off and starting over. You could also try using a c-clamp half way down the flaring bar which helps reenforce the flaring bar from flexing.
What you did when it slipped is actually extruded the brake line making it smaller diameter.
