Stock SS suspension question
Get a set of Koni SAs,
Front:
Koni SAs up front with (snap ring in the lower groove)the lower spring seat on the lower perch.
Rear:
Koni SAs (3rd or 4th gen.), and the "Hose Mod" with the rear springs.
This is a popular combination with the factory springs, and the only one I would recommend!
Front:
Rear:
Front:
Rear:
Front:
Rear:
do you have any pics with this set up
Your only expense would be for the Koni's and unfortunately the Koni's arent cheap. But the improvement in ride and handling is incredible.
Are you ready.......?
http://www.stranoparts.com/partdetai...ID=0&ModelID=7
Yeah you can get them for a little less else where, but I doubt you'll find better customer service.
hose mod is really easy. jack the rear up, put jackstands under the rear sub-frame so the rearend lowers a lil, pull the springs, remove the isolators and place heater hose around the last coil on the spring
took me about 15min to do
