Baer Plus 1's I am interested in getting the Baer plus one rotors, I see in the pictures they have brackets to go with the rotors. I think this is to move the caliper out due to the larger rotor, but I can find any instructions or tutorial on the install. Can you guys help me out if you have any info on the installation of the front and rear Baer plus one rotors? And does anyone know if this rotor and bracket combo also work with a C6 Z06 caliper? Probably not I am just thinking future upgrades after the rotor swap. Thanks guys. |
I run them, plus their upgraded calipers. It's very easy. You have to unbolt the front wheel hub, then the bracket bolts to the back of the hub. Easy. You also need a sawzall to cut the lower ear where the stock calipers were bolted. Easy. |
| All times are GMT -5. The time now is 10:05 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
