LCA's and relocation bracket problem??? I just install UMI non adj LCA's with the relocation brackets. I followed all the instructions, greasing, and all...but my rear end creeks? Any idea why it is doing this? |
Did you have the weight on the tires when you torqued them to spec? |
no i didnt should i loosen them and re do it with the weight on the tires? |
Originally Posted by GoHardZ28
(Post 11248547)
no i didnt should i loosen them and re do it with the weight on the tires? Also besure to use a fully synthetic bushing lubricant as petroleum based products do not work as well at preventing creaks. Petroleum based lubricants will also degrade the busjings faster causing premature bushing failure. |
I just finished the reinstall and it worked pretty well. There is still a minor creek but i may need more grease. Thanks for the help |
Lower Control Arm Relocation Brackets Hello Thank you very much for your business!If you have any other problems feel free to contact me and I will be glad to help! Thanks Brad :D |
| All times are GMT -5. The time now is 09:36 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
