View Poll Results: What is universally the best brake-type?
Voters: 147. You may not vote on this poll
Slotted vs. Drilled & Slotted (Poll)
#41
I talked to strano since he's the handling guy and I asked him about brakes. I was about to spend $1200+ for a baer front caliper and rotor, and rear rotor kit. That's a big brake front kit.
sam said no need for a big brake kit which will have the same # of pistons in the calipers as we have now for stock. He said if it had mor pistons then maybe it'd be worth it.
I asked about the cross drilled/ slotted/ plain issue too and he said blanks or slotted. I asked why some cars come with drilled stock like the zr1, he said look at the material they're made of. Every little thing matters.
drilled-looks good, but will eventually crack if used too hard
slotted-looks good, they say they'll eat your pads because they slice and yada yada, but I don't see how if you don't MAKE them slice by using them hard. Under hard use maybe then they'll eat pads, but normal use I don't see them being any different than difference in life of softer compound tires. There may be a trade off on life span but just like softer compound tires it depends on how you use them. I haven't had mine long enough to tell you.
Plain-low risk of cracking, holds the most heat(more material), easy to find. I'd say under extreme use they don't keep the pads cool as the others which will cause fade.
#42
LS1TECH Sponsor
Drilled is about looks, pure and simple. You lose a good bit of swept area, and you structurally weaken the rotor much more than by slotting. And make no mistake, very few rotors are meant to be drilled, and those that are have it taken into account.... The OEM replacements for our cars are NOT meant to be drilled. But some want that bling!
Slotted rotors come in various degrees too, from sucky to excellent. Slotting can be done cheaply and in a half-assed way, and it can be done on cheap rotors too. The combination is even worse than either thing alone.
The only slotteds I like are the ATE's. No they aren't cheap. To begin with they are made by a company you know (or should if you are into cars), Continential-Teves. They are coated, they do not have points at the ends of the slots (because the pattern leaves no ends) that act as stress risers. And they are coated too, all for a very fair price. I can get and sell cheaper rotors... I don't like to because it becomes a hassle. I'll be accused of being a parts snob for it I'm sure, but there are reasons things are cheap---because they are cheap. If you want the brakes to work as they should and last then cheap isn't the best answer. If you are about looks and performance and quality can take a back seat, there are lots of cheap E-bay like options around.
__________________
#43
The z06 and zr1 have different brakes.
Front/Rear
Z06 = 14/13.4 in diameter rotor
ZR1 = 15/15.5 in diamter rotor
#45
For one thing this poll doesn't really give an option for blanks. When you say I prefer stock, it makes it sound like we'd take the stock OEM rotors which are prone to warping. Some people say there's no such thing as rotors warping, but then that would still make the stock rotors more prone to "glazing" or "transferring more pad material, making the stock rotors uneven". Regardless if it's actually warping or not, stock rotors carry these unwanted characteristics.
#46
LS1TECH Sponsor
And they use different calipers (Brembo for the ZR1, PBR for the Z06) and the Z06 has 6 little pads per front caliper, the ZR1 does not). In fact the brakes are quite different all around but for both having 6-pot front and 4-pot rears.
__________________
#48
LS1TECH Sponsor
What do you mean, what type? They Z06 are drilled, but unlike replacements for our cars, they were meant to be drilled. Further, they have fewer holes tham most aftermarket drilled ones do, and the rotor is a lot bigger @ 14", and designed that way too.
__________________
#49
Yeah I'm talking rotors, and admitted I was wrong. I'll let ya know when I start talking brake systems. Thanks though.
#50
Nevertheless, I will never trust a cross-drilled brake rotor over a solid rotor for the same given material composition, mass and dimensions no matter what the duty will require (exception being using pads that outgas continuously throughout the duty, e.g. some "Pagid" branded competition pads).
For those who want to read that SAE GM report, I as an engineer have read it and whilst it has some truth to it, it's mostly tainted by it's miniscule testing procedure, not to mention it has only somewhere around 24 pages with only 4 references. I've read senior year mechanical and materials engineering students provide much better data with much more consistent results over very similar applications, and their report results are very consistent with all of the problems that are associated with drilled rotors. If GM shall approach their study with much more consistency and with much more drawn out details, than I think they too will observe what has been stated about drilled-rotor failures.
Again, it's more relevant to the engineering and less relevant to a major vehicle manufacturer posting a report to a very significant organisation. In short, just because it's a peer-reviewed GM report posted with the Society of Automotive engineering doesn't mean it's ultimately accurate.
#51
i use drilled/slotted rotors and DO HAVE PROBLEMS.
this is after a few thousand miles.
this style of drilling is advertised as resistant to cracks...
i'd really recommend GOOD blanks with good pads, but if you gotta have drilled holes or slots, i would go with brembo slotted rotors.
i've had oem rotors, cheap drilled/slotted rotors, ebc sport rotors (great) and brembo slotted (best) and to be honest, the brembo slotted rotors were the best out of all. the ebc slotted/drilled had less fade and would take it like a champ going a few miles going up/down a curvy mountain road, but took considerably more pedal effort... then again that could have been the ebc pads too.
#53
If you want a solid proven combo that will last you through the life of the rotor with no worry, get HPS brake pads and Brembo blanks. If you still question that, do a search on them and no question will you get the confidence of many users and experienced track drivers.
#54
LS1TECH Sponsor
Brembo's are great, but I'm using and recommending more and more ATE's these days. The cost is not a lot different, and many like the fact the ATE's are coated to prevent hat and edge rusting.
None the less not everyone likes the ATE look and I can understand that. I have packages that included HPS's with either Brembo or ATE rotors (and yet other that then add stainless brake lines and ATE fluid too).
__________________
#55
#56
Crap... I have to pay to access that document I'll keep searching to see if I can find it because I'm interested.
I don't agree with Stoptech on the warping rotors. I believe our stock rotors actually warp. I don't see how the brake pad transfers its material right into the rotor.
I agree that stock rotors can warp easily. I've warped a few sets in my time from crappy pads and overheating the brakes. - Mostly on the Bonneville, Grand Prix (RIP), and one set on the truck (doing what I wasn't supposed to be doing). I've heard ceramic brakes are the quickest way to warp them under severe usage.
My rotors on my 02 TA are glazed up badly from several years at Woodward Ave, constantly on the brake for 18+ miles.
I'm no brake expert, but I would think that there's a very thin gas or material layer that the brake pad and rotor are separated by. Once that micro thin layer breaks down, you can have metal to metal contact, and if severe enough, transfer material.
Remember...your talking about thousands of degrees of temperature. It would follow the same theory of engine bearings and journals. ONce you break down the oil film and make metal to metal contact... It's easy to make material transfer. (Photos of this at my photos page -3800)
I searched out this thread actually to find out what's best to upgrade on the car.
The brakes were good on the 02 when they were fresh. Now that they're glazed....they're awful. I was fooling around up north a couple years ago, and found out - whoop...buck 30 and NO BRAKES!!!! I have been tip toe'ing since.
I may take the rotors off, have them de-glazed/freshened up and inspect the pads. I've only got 5700 miles on them.
C
C
Brake judder is primarily caused by the formation of hard nodules in the iron. Engineers call these nodules heat spots. When I measure warped rotors, I find that the radial runout as referenced to the wheel mounting surface is in spec. So the term "warped" rotor may not be an accurate description of the problem. However, my dial indicator shows elevated bumps from heat spots on the rotor surface. As the rotor passes under the pad, these spots cause brake judder, i.e. pulsating brakes. It only takes a spot .001 inches above the rotor surface to feel brake judder.
Pulsating brakes start with a localized zone of high temperature in the rotor. The most common cause is uneven friction deposition on the rotor. At colder operating temperatures (less than 400 degrees), brake pads work with abrasive friction, just like sandpaper on wood. At higher temperatures, brake pads transfer a thin layer of material to the iron rotor surface. As the rotor heats up, the primary friction force changes from abrasive friction to adherent friction, i.e. pad material is applied to the rotor and simultaneously sheared and the broken chemical bonds cause a resistant friction force. Most racing pads work using adherent friction, which explains why racing pads don't really stop well under cold conditions or normal street driving.
An example of an uneven friction deposit is pad resin glazing. If you get your rotors hot, the resin from the pad will liquify and glaze on the rotor surface. As the pads rub on the elevated glazed surface, it gets a lot hotter, and the heat is localized in just one area of the rotor. When the temperature exceeds 1150F, the cell structure of the iron changes into hard brittle spots called cementite. These heat spots don't wear down like the normal iron material surrounding it. So the spots become elevated above the rotor surface, and you start to feel brake pulsation. You can try to turn down the rotor, but the cementite nodule is often deeper than the cut, so the brake pulsation just comes back after a few weeks
I always say this and I'll say it again. Instead of making a public poll here and going with the best result, I would try to figure out who the experts out there are on this stuff and base your decision on that. I think you'll come out with better overall results in the long run.
#57
LS1TECH Sponsor
ATE does have rotors for the C5 (they are even directionally vaned).
One more thing to note. I now carry Racing Brake brand rotors. These are a step beyond the normal street rotors. Meant to take a track pounding and live. The fronts for the LS1 in stock replacement size are directionally vented/vaned... The only ones like this in stock size for the F-body.
__________________
#58
ATE's have the elliptical slotting. But unlike traditional slots, they have no sharp points or edges, and are not cut deep. When the rotor is down to minimum wear thickness the slots actually wear away to tell you and also that thinner slot means less material is lost and the rotor remains stronger.
#59
LS1TECH Sponsor
They exist (too late for you now that you have C5 brakes....), but for the others, here they are:
http://www.stranoparts.com/partdetai...D=17&ModelID=7
__________________
