Rear Sway Bar 4 moser 12 bolt
Want to know what everyone is using, I have a moser 12 bolt w/ qa1's and a spohn rear sway bar and the sway bar is rubbing my shocks and I need to get it fixed asap. let me know what you guys have and or what you have done to get it to work
What are you running for swaybar mounts? I'm running the stock swaybar currently on a Moser 12-bolt with exhaust clamps and Strange SA shocks. I plan to move to the Spohn 1" stock style swaybar soon and install the Spohn mounts for some added clearance with the rearend. Where are the shocks rubbing? If just on the adjusters, turn the shocks 180 degrees so that the adjusters are on the outside of the shock.
