LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Suspension & Brakes (https://ls1tech.com/forums/suspension-brakes-16/)
-   -   What's your LCA Angle? (https://ls1tech.com/forums/suspension-brakes/1127361-whats-your-lca-angle.html)
Grn4fbody Jun 2, 2009 11:03 PM
I had a local guy look at my car a couple of months back since after my Cam/Clutch/bolt on install over the winter my car wont hook for SHIT (cut a really nice 2.7 60 foot on ET Street Radials)
The PA is dead on but he said my LCA's are way to low (7 degress) so I adjusted them up the top hole on my LCA Brackets and there sitting at 5 Degress. Also no hooking even on some 26 11.50 16 ET Street's.
The other day I did the hose mod and got it right above 3 degress and haven't drove it yet, just seeing what everyone else set's there car at.
It's a factory height M6 car
Wiktorek25 Jun 3, 2009 10:10 PM
practice practice practice
Grn4fbody Jun 3, 2009 10:55 PM
If your talking about my driving ability that's not the factor because before all the mods I could cut 1.7's all day long
flash12t Jun 6, 2009 08:20 PM
well i use my lca at the lowest hole on the relocation brackets
there a couple threads about instant center thats where those hole come big into play with hooking. . . but ussually the lowest hole will best the best choice
97Z28SS Jun 7, 2009 10:30 AM
With weight on all four tires the rear of the lca where it mounts to the rearend should be level with or lower than the front of the lca, this will provide the most anti-squat and your pinion angle depends on wheather your car is a m6 or a4.
© 2026 MH Sub I, LLC dba Internet Brands
