chrome moly LCAs worth it?
on a lower control arm...absolutely no benefit regarding deflection given the same wall and diameter. Stay away from some of the overbuilt heavy configurations. You're not gaining anything by an overbuilt product that is adding unsprung weight.
http://www.hotpart.com/shop/index.ph...ct_detail&p=61
Our 4130 Cr Mo. LCA is USPS scaled at 2lbs 12oz. Our setup is 199.99 complete and includes an upgraded 1/2" bolt kit.. We use 1.25" OD diamater tubing with a .095" wall. All tig welded of course.
They are located here: http://www.sjmmanufacturing.com/deals.html#
i know people who have been autoxing and road racing with those LCA an have had no issues whatsoever. i know someone with a late model dirt car, uses the same kind of aluminum parts on everything, and nothing has gone wrong. the rod ends will pull out of the threads before they ever bend or brake. and this is going through dirt, potholes, mud, not to mention beating and banging other cars.
Thread issues will arise overtime between the aluminum thread of the ends and steel thread of the rod end. Galling is a reality. The rod ends male thread will have a tendency to loosen in the female aluminum end...this will create galling as well as increased tolerances. The life of the component is limited whereas stress cracks can/will occur.
If you compare it to other setups ...components using those heavy Johnny joints or other unnecessarily overbuilt and overly heavy configurations etc., than you may consider weighing benefits...
For the advantages of steel in direct comparison to our products ours are a far better value and will perform better and last longer.
