Spohn Drive Shaft Safety Loop ?'s
I am interested in a Spohn Drive Shaft Safety Loop. I have two questions, first will there be any clearance issues with the driveshaft itself after a set of UMI 3 point SFCS installed. I assume the drive shaft loop is supposed to be installed after the SFCS therefore removing clearance between the top of the loop and the drive shaft. Second, is the drive shaft safety loop a better alternative than the stock tunnel brace as far as stiffing up the suspension and getting better performance. Thanks for your time.
