need assembly instructions for 2 1/2" spring adapter for QA1 front single adj QA1 apparently doesn't reply to e-mails.. been on hold for an hour.. 4th gen front single adjustable QA1's.. was using the stock spring with my fabricated lower spring cup.. now I've gone to the 2 1/2" spring... bought the adapter kit.. but I don't know what to do with the stock upper spring cup/mount.. the stuff in the kit can't possibly work on their own.. any info would be greatly appreciated.. Thanks Ahead! Matt |
Originally Posted by MattSLONOMO
(Post 11819256)
Originally Posted by 99Bluz28
(Post 11819567)
So this is a QA1 Adapter kit, do you have a model/parts # for it? QA1 Coil over stud top conversion kit for 2-1/2" spring part # AQ1/SS112SDM QA1 upper spring cap part# QA1/9018-101 |
I'm not having any luck finding any info on those part numbers, even on the QA1 website!:confused: Where did you get you info from, do they have any photos? |
turns out.. they send ya parts you don't need..although you pay for them.. the bushings are not used.. |
Great, sounds like you're good-to-go!:thumb: |
© 2024 MH Sub I, LLC dba Internet Brands
