master cylinder
master cylinder
How hard is it to replace the master cylinder, and how much do they usually cost? My brakes starting screwing up and i bled them today. no luck. Pretty sure its the master cylinder.
thanks
thanks
Changing it out won't be bad, just disconnecting the brake lines and the two nuts to pull it off the booster. You will need to bleed the brakes afterwards though.
