150k maintaince
150k maintaince
what things suspension would be bad at 150k. shocks but wont relize how bad they are untill i put new ones on. ball joints. what other bushings? should everything be changed to moog?
what bushings. plan on getin lca so i wont need those bushings. what others. inner tie rod ends should be fine i only need outer right.? and from what i hear i dont need upper ball joint? only lower
A suggestion for you that will save time and not be a hassle!
Hello
I noticed that you are interested in a suspension upgrade! And I just wanted to leave you know that If you are looking to get better performance out of your vehicle. I would suggest just replace the rear lower control arms and pan hard bar seeing how they are just a stamped factory piece. UMI Performance offers a few different versions of rear end suspension kits. They all feature Energy Suspension and are grease able. Below is a link to show you what all we have to offer.
http://www.umiperformance.com/catalo...db38mtnrv8q520
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks
Brad
