Got some used Konis, what hardware do I need?
Do you have these, for each shock?
Bayonet mount nut, metal lower spring seat and plastic spring indexing seat, snap ring in lower spring seat mount grove, Koni bump stop on shock shaft, large washer 1/8" thick, with a 3/8" or 7/16" hole ?, and it's 2-1/8" diameter.
For the lower shock mounts just reuse the factory mounting hardware.
