umi tq arm relocation and lca's instructions?
whats up fellas i just recently got my pile of suspension goodies and either i can't find them or they didn't come with it (instructions). i have the tq arm instructions but i don't have any pictures or instructions for the relocation bracket the (tq arm mounts too).
i also don't have any instructions for the lca's. where do i grease them btw?
im going over the directions of the other stuff and trying to get everything ready for install this wk (was suppose to do this today but a 230am dd request an late night made me sleep late good wing man)
any tips from you guys until umi keys in here on monday or when i talk to them? i will be charged by the base shop while im there so i want to be on top of things.
again where do i grease my phb and lca's? both are poly/rod adj.
thanks if you can
thanks if you can
lol no sooner i get up to look for it again i found the directions for the tq arm relocation kit don't you love when you do that. i went over it a couple times and the only thing i don't get for us manual trans guys is that we have to lower the trans in order for the holes to line up? i guess ill have to find out.
btw, i still can't find my lca instructions
The torque arm relocation kit replaces the stock crossmember, you have to remove the old torque arm mount in its entirety in order to use it. That includes the clamshell side with the bolts that go through the tailhousing, which you can't get off without letting the transmission droop (or by cutting the stud that is attached to the clamshell).
I have UMI's adj. T/A model number 2200, are you talking about another model?
