Lt1/ls1 rear brake swap
Do LT1 rear brakes bolt directly into an LS1 car? I have a set of Summit Draglites 15's that can't go on without grinding 1/2 the calibers away. I hope someone can help, i'm tired of grinding. Thanks
Thats what i'm trying yo find out, if everything bolt up directly the same. Just LT1 brakes are a little smaller than LS1's
what about the front brakes,,, everything i keep reading is about LS1to an LT1 swap, and i want to go the other way, as anybody changed from LT1 to an LS1 brake set up. i have calipers front & rears , new 12" rotors, spindles, brake lines, back plates, proport value,etc. is there any thing else i'll need before i go and tear the car down.
I did a lt to ls rear and lt to ls/cts-v front. Its been a while but I think he backing plate for the rears is diff u will also need the parking brake lines. U will have u open up ur rear end also easy job worth doin
