WTB: 01-02 Electronic Brake Control Module (EBCM)
Old 10-09-2009, 05:31 PM
Lots of Speed 1's Avatar
Default WTB: 01-02 Electronic Brake Control Module (EBCM)
I am looking to buy an EBCM that is from an '01-'02 V8 car that had traction control and ABS. The one I am looking for has 10 "wave springs" they look like little cylinders.
Let me know what you got.
Thanks!
Old 10-09-2009, 05:45 PM
01 ss vert's Avatar
FYI, when you replace the unit, there is no need to take off the brake lines. There are 6 torx screws you and remove and change out the black, electronic unit. I did this a few months ago and it saves a lot of time vs changing out the distrubution block as well and then neeing to bleed the system.
I got mine off a wrecked car...I heard to make sure it it's the proper channel (3 or 4), but I can't confirm this. Fairly easy fix.
Old 10-10-2009, 06:30 PM
Yeah I know what you are saying. I actually bought one from someone on here, but it wasn't the right one. I didn't figure out it wasn't the right one until I took it apart. Before I took it apart I was afraid that I was going to have to take the brake lines off and bleed the ABS system, but it's actually pretty easy; now if I can find the proper EBCM
Old 10-11-2009, 12:50 PM
Anybody have one for sale??
Old 10-12-2009, 11:07 AM
kevinkr's Avatar
Thanks!
PM sent.
Old 10-26-2009, 11:26 PM
2001ls1's Avatar
Default (ebcm)
I'm in need of 1 myself, same setup for an 01' with ABS & TC. I did locate a Co. that rebuilds EBCM's, but was hopeing to locate 1 for less $.
Old 10-31-2009, 08:49 AM
NArtissimus's Avatar
I've got one for sale.
Removed from an 01 Z28 with ABS and Trac Ctrl (4 channel).
I'm Vancouver Canada so shipping may be costly but it's an option.
PM for more info.
Art
Quick Reply: WTB: 01-02 Electronic Brake Control Module (EBCM)
