New SS Vert owner needs help improving handling
Hi guys
I need some help improving the handling of my 1999 Camaro SS convertible. It is completly stock with 50k mi. I'm currently serving in the Army in beautiful Baghdad, Iraq. I'll be back home in a few months finshing out my 10 month tour here. I'm planning some mods to do to my car when I get back.
I want to lower the car about 1"-1.5" and keep a nice plush ride while stiffening up the chassis for better handling. This is not a drag car, it's my daily driver.
Please give me the brands you reccomend and any personal experience you guys have.
Thanks in advance
Jason
Thanks in advance
Jason
Welcome to the Board.
Here are the handling and braking mods I've done to my convertble:
Suspension & Drivetrain Mods: BMR Shock Tower Brace, BMR Tubular Welded Subframe Connectors, BMR Adjustable Panhard Bar, BMR Tubular Lower Control Arms, BMR LCA Relocation Brackets, BMR Adjustable Torque Arm, BMR Solid 32mm Front and 21mm Rear Sway Bars w/ Poly End Links, BMR Tunnel Brace, Transmission Poly Mount, 3.42:1 Rear Gear, TA Performance Girdle, Custom Cut SLP Eibach Coil Springs, Bilstein Shocks, FIKSE Profil 13 Forged Aluminum Wheels: 18”x9.5” Front & 18”x10.5” Rear, 275/35ZR18 & 295/35ZR18 Kumho Ecsta MX Tires, C5 Corvette Front Calipers, Baer Eradispeed Cross Drilled & Slotted 13.15" Front & 12" Rear Rotors.
The car handles great and runs like it is on rails!
