BMR adjust PHB- need info please
Hey guys, my car is lowered about 1.25 inches (hypercos)- just wondering if the bar needs to be longer or shorter than stock. Any ideas as to what length to start with? I have access to an alignment rack as well. One other note, didn't have the bolts so I found some 8.8 grade I believe m12 X 70MM that fit nicely but there is some slop between the bolt and the metal sleeve it goes through. I would imagine that's normal. Thanks for any help.
Follow the directions that came with the BMR phr. If you don't have them, they are on BMR's website. They give probably the best way to align your rearend properly.
Your best bet is to set it to the stock length (measure it up with the stock phr).
Just use the stock bolts if you have them, here's a install link. http://www.bmrfabrication.com/instructions/phr002.htm
Al
Al
