Give me your honest opinion...
Old 12-22-2009, 07:21 PM
Dubyaesix's Avatar
Default Give me your honest opinion...
I just picked up this WS6 about 2 weeks ago and my first mod was to lower it. I lowered the front with some Hotchkis springs from Jegs and I did the back using the "hose mod" I learned from LS1Tech (thanks BTW!). The whole process took about an hour and a half for the front and literally 25 minutes for the rear. I didn't use lowering springs for the back because I wanted just a little bit of rake. Please tell me what y'all think. Thanks!
BEFORE:
AFTER:
ONE MORE AFTER SHOT:
Old 12-22-2009, 07:27 PM
ssam98's Avatar
LOOKS GOOD BRO.
Old 12-22-2009, 07:50 PM
Ericbigmac83's Avatar
dunno, i think ya gotta do the back too
Old 12-22-2009, 07:58 PM
223HAWK's Avatar
Looks good(front=perfect!) but I think Id do the rear..Get some 18s and itd look sick!! Nice Ride BTW!
Old 12-22-2009, 08:04 PM
Breathing Fire's Avatar
To me I'd say it looks really good. Having said that about another.5" off the back would be my favorite. A raked look to me isn't bad. It is way better than the sagging *** syndrome. Anyway good job I like it.
Old 12-22-2009, 08:22 PM
pjb
pjb's Avatar
the rear is too high
Old 12-22-2009, 08:25 PM
lemons12's Avatar
Looks good, I say lower the back some more too though..
Old 12-22-2009, 08:33 PM
Pseudonym's Avatar
I like it. With bigger wheels it will look even better.
Old 12-22-2009, 09:13 PM
Sold The Fun Stuff :(
josh99ta's Avatar
A little rake is nice, a lot of rake looks like you lowered the front but didn't lower the rear (which is what that looks like). Cut a coil off the rear springs or swap in some rear lowering springs whether they be Hotchkis, BMR, Strano, Vogtland, or whatever. The back needs to come down bad IMO. The front looks amazing!
Old 12-22-2009, 09:32 PM
Dubyaesix's Avatar
Thanks for the honest feedback guys! It's rather apparent that I need to go ahead and lower the back too. My only other concern is that I was going to take it to the muffler shop next week and have them fab up a true dual exhaust setup with dumps right before the axle. I'm afraid I won't have enough clearance if I lower the rear as well. Anyone have a lowered F-body AND TDs dumped?
Old 12-23-2009, 07:48 AM
teke184's Avatar
lowered and dumped TD here.
i've got BMR 1.25" springs, and 3" tds with full size magnaflow 4x9 mufflers.
the mufflers sit right under the rear seats, and are tucked up within 1/4" of the floor pan or so. they are the lowest part and have right around 2.25" of clearance.
if you ran bullets or a chamberd muffler you could tuck the pipes/muffler farther up in the trans tunnel and get a little mroe clearance. but then the pipes would be the lowest part.
although running 2.5" pipes would help that.....as stated, i'm running 3" pipes.
here are my pics: last one is it sitting on the ground looking back
my rear is just a little too low, even though the wheel wells are basically perfectly even all around. i'm planning on putting a 1/4" spacer to boost it just a smidgen. also may put a 3/8" spacer in the passenger side since that side is lower (very common).
Old 12-23-2009, 08:35 AM
CUR 4 VNM's Avatar
lower the back too. but the front does sit nice
Old 12-23-2009, 09:36 AM
Engine_HP's Avatar
looks good to me.
Old 12-23-2009, 02:00 PM
Siciliano15's Avatar
the way the car sits now is perfect. u dont want to lower it anymore in the back if you like the rake. muscle cars should have a little rake these arent imports or california lowriders
Old 12-23-2009, 02:17 PM
223HAWK's Avatar
Maybe a 18/19in wheel combo would change the whole look??
Old 12-23-2009, 02:30 PM
1qwkz's Avatar
leave the back how it is, for future track plans having it lower in the back will slow your 60fts not being able to sqaut as hard
Old 12-23-2009, 06:25 PM
YellowToy/A's Avatar
It is your car. If you like the way it look dont cahnge it. By the way I did not lower the back and I like it that way.
Old 12-24-2009, 07:19 AM
UMI Sales's Avatar
Dude that's a nice ride! Good luck
Brad
Old 12-24-2009, 07:27 AM
99FormulaM6's Avatar
Try the hose mod in the rear.
Old 12-24-2009, 02:15 PM
1slowM6's Avatar
looks good,drop the back just a little and you will be set
