Jacking With Aftemarket K-Member?
Hey guys....I am wondering, those of you with aftermarket K-member installed on your F-bodys, can you lift the front of the car with a floor jack? (placing the floor jack on the K-member) Or, is that not a good idea?
UMI says that theirs was designed to be jacked on, though you should use a piece of rubber to avoid chipping the powdercoat. BMR says that it will work but it is not recommended. No info on spohn.
