HAL's springs sag can I use an Afco spring
Like title says above will the afcoils springs drop right in place of the Hal QA1 coilover spring? My tires hits the inner fenders with the skinnies and wantin to go to a heavier rate spring? The crossover on the exhaust to the turbo header is only like 3 inchs off the ground and needs to be a lil higher. Thanks Justin
