Suspension For ME!
Vehicle is a 2000 Z28 M6, currently only running an SLP Lid, Loudmouth II, Ground Control Coil Overs, and Bilstein SLP shocks. Everything else is stock. My plans are long tubes, catted Y, and a Cam later on down the road. I do not have plans for a power adder or extra cubes. Basically i'm aiming for somewhere around 400WHP give or take some... so not a particularly high horsepower goal, fairly mild compared to most of the cars on this site.
Now for what I want to do with the car. The car will be street driven, and will see SOME passes at the strip. I am more concerned with straight line performance as opposed to road racing and have very little to no concern regarding ride quality.
WIth all this taken into account where should i start as far as LCA's and a panhard bar? I realize that because the car is lowered it is wise to go with an adjustable set up, but there are sooo many options available. Double adjustable, rod end, roto joint, poly, etc. All the options available make my head want to spin!
Thanks in advance everyone for any help. It is much appreciated!
a street car you would want a poly/rod adj or the new rotojoint are supposed to be really nice pieces too. The dbl adj just gives you more room for adjustment and more fine tuning
Thanks for supplying us that information.
Based on what you have supplied I would recommend polyurethane bushings for your application. Non-adjustable control arms will be just fine, I see no need for anything else there. I do recommend the adjustable panhard bar since the car is lowered and relocation brackets are always a great idea for increased traction. The relocation brackets are also a great idea for you since the vehicle is lowered, it will help to place the control arms back in the stock location. The polyurethane bushings are greaseable and very street friendly, they will not offer any additional noise or any type of a rough ride.
Below I posted links to the items I would recommend.
Control Arms- www.umiperformance.com/2015
Panhard Bar- www.umiperformance.com/2029
Relocation Brackets- www.umiperformance.com/2012
If I can help anymore please ask and I am glad too. Thank you!
Ryan
Depending on what lower control arm you look at there is different types of benefits. We recommend adjustable control arms if you are installing an aftermarket rear end. Most aftermarket rear ends do not sit centered in the wheel wells and adjustable control arms are used to center the rear end. This is very common with Moser brand rear ends. Also 28" tall and taller tires usually require the rear end to be tweaked back or forth slightly for clearance and to prevent them from rubbing. Other benefits are, if the control arms have rod ends the rod ends prevent bind and allow the suspension to articulate. However for a street car the rod ends may increase noise and reduce road quality.
Does that answer your question?
Thanks!
Ryan
Sorry OP....didn't mean to thread jack!
Just one more question, i see that purchasing new hardware is an option. With my application would it be wise to go ahead and use new hardware as well or is it a moot point for my app.? Thanks again everyone
I understand that the roto joint set ups are geared more closely to road racing but would these hurt straight line performance... especially with my application being relatively low power? Reason being is the two birds one stone mantra, if its going to obviously help handling without sacrificing straight line traction i definitely would not mind spending the extra coin.
Sorry for all the questions! Thanks again everyone!
Now as far as the pan hard rod should i run the roto joints on BOTH ends or is the combination roto/poly a better option?
Thank you very much UMI and LS1Tech members! I will definitely help stimulate the economy through UMI performance!
Thanks
Brad
Hope that helps!
Ryan
