Need Torque Specs for BMR LCA's....
Old 12-28-2003, 10:03 PM
Ferocity02's Avatar
Default Need Torque Specs for BMR LCA's....
I just installed mine and want to make sure I got the specs right. I torqued the front bolts to 100 ft/lbs because I have the BMR boxed SFC's, and the rear bolts to 94 ft/lbs. Should this be okay? Thanks.
Old 12-29-2003, 04:43 AM
DARK AGE 53's Avatar
If you're using a torque wrench on the head of the bolt it's 80 ft/lbs, nut end is 60 ft/lbs. I would think if you over torque the bolts you could cause some binding with the LCA. JMO http://www.ls1.com/rearsuspensionsto...ifications.htm
Al
Old 01-05-2004, 03:33 PM
NOBR8KSS's Avatar
I torqued mine on the bolt and nut sides to 74 ft-lbs (front and rear) per the instruction that came with them.
