Need to raise the car up a little bit
Old 03-07-2010, 06:14 AM
RsSean's Avatar
Default Need to raise the car up a little bit
I have a 2000 SS with the Pro kit, after the install of my MWC 9 inch, the car seems to bottom out really bad even on the the smallest of bumps. I was wondering if there was a alternative to buying new springs for the rear, just want BANG BANG BANG to stop. The rear islators are still in the car.
Any ideas. Maybe a spacer between the bottom of the spring and rear end? Or stop being a cheap *** buy some strano rear springs. LOL
Old 03-07-2010, 06:41 AM
02Z28LS1's Avatar
what shocks do you have? if you're still on the stock shocks, i'd consider upgrading, it just may take care of the issue.
as for raising the rear, you can either get different springs, or you can add a spacer between the rear & the bottom of the spring....either way should work just fine.
Old 03-07-2010, 07:07 AM
RsSean's Avatar
KYB AGX 8 way adjustables.
Do you know who make such spacer. I Pm'd Sam to get a price on the rear set of springs.
Old 03-07-2010, 08:11 PM
02Z28LS1's Avatar
i don't know of anyone that makes a pre-fabbed spacer, although that's not to say they don't exist...i just don't know of any.
probably your best bet would be to go to a local machine shop and have them make some for you.
Old 03-07-2010, 11:03 PM
Pilsner's Avatar
Reverse heater hose mod, add some heater hose to the top and bottom of your springs, should give you 3/4". It's a easy and cheap.
Old 03-07-2010, 11:43 PM
02Z28LS1's Avatar
sorry, there's no way a piece of heater hose wrapped around the top coil is gonna give you 3/4". MAYBE 1/4" - 3/8" at MOST.
now, if you put a larger piece of hose over that one, then maybe 3/4", but there's no way with just one piece
Old 03-08-2010, 12:08 AM
StrokerAce03's Avatar
The bottom of the spring is designed to sit over the mounts on the axle to keep it from popping out. IDK how it would do with a spacer on it. Taller springs would be safer I'd think.
Old 03-08-2010, 12:26 AM
WS6-R's Avatar
I agree...except for the 3/4 lift.
Old 03-08-2010, 12:48 AM
99bluehawk's Avatar
Ask the guys with 26 inch rims on there box chevys they might now how. lol
-Bert
Old 03-08-2010, 06:16 AM
FirstYrLS1Z's Avatar
https://ls1tech.com/forums/suspensio...wered-car.html
Old 03-08-2010, 08:33 PM
Chris05ssTruck's Avatar
Sean, it's the TQ arm hitting the bottom tunnel of the car more than likely; not the car bottoming out like you think....
Old 03-10-2010, 09:01 AM
RsSean's Avatar
Well the axles is literally riding on the bump stops, and the torque arm has a 1.5 inches before it contacts the tunnel, so I think it is a little of both and it is freaking annoying.
Old 03-10-2010, 06:02 PM
leadfoot4's Avatar
I think that Moog makes a "cargo coil" for the rear of the F-bodies. Could be an inexpensive and easy to obtain solution....
Old 03-10-2010, 07:30 PM
RsSean's Avatar
^ that may be a little exessive. But for 61 bucks from summit it may work.
Old 03-11-2010, 04:24 AM
If it's just barley tapping the bump stops all the time.....cut them off....
Old 03-11-2010, 06:15 AM
RsSean's Avatar
Well Sam Strano is out, racing this week so I am think I am just going to get his rear springs that are 1.2 lower in the rear.
If i cut the bump stops off the Tq will slam into the body that would just cause more problems
