what else do i need to lower my car 1.5in?
if 1.5" is too much to lower it, what would you guys go to? 1"? i'm curious ... i have a stock suspension '99 z28. i just logged on here to research lowering it. i have to do some suspension maintenance in the near future (approx 200k miles on it) and wondered about lowering it at the same time that i swap in new bushings.
On the other hand, saying that you want to lower a car a specific amount, based on a spring manufacturer's estimated drop can be misleading. The reason I say this is because I've observed a LOT of Camaro/Firebirds over the years, and I truly believe that the stock ride height varies quite a bit.
Therefore, lowering a car 1.25", for example, if it's at the "high" end of production spec may actually put you maybe only 1/2" lower than a car that started out at the low end of the spec. Along that line, take a car that's already at the low end of the spec, and drop it the same 1.25", and you're "in the weeds".....
I have a setup I'm going to do once my Bilstein shocks come in. New design BMR lowering springs and Bilstein shocks. The BMR lower the car 1.25" Just hope it turns out okay and don't beat me up to bad, hopefully not at all. Bill the reason why we say 1.5" is too much is because if you at LT's or an after market exhaust it hangs lower than the stock most of the time. That's why you see guys buying higher dollar header's and higher dollar catbacks so hopefully they don't lose much clearance. So if you go with LT's you may lose a tid of clearance and then you go down to 1.5"-1.8" then you start scraping everywhere and then that takes the fun out of driving the car and then you won't want to drive it cause it gets so annoying and you get tired of dealing with it and sometimes no matter how slow you go over a speed bump or how good you cut it you scrape. But it kinda depends on the exhaust setup as well. Did mean to hi-jack the thread.
1.25 does seem to be a good drop on these cars
