Tunnel mount tq arm bolt size
Hello
I am not really sure what bolt you are talking about. So I will just give you the hardware sizes for the complete set up.
Mounting hardware for the mounting bracket to the rear end- (2) 9/16 x 7 1/2
Solid rod ends to mounting bracket- (2) 5/8 x 2 1/2 & (2) 5/8 X 11 Nylock Z nuts.
Shackles for the front of the arm to the cross member- (2) 1/2 x 3 & (2) 1/2 conical lock nuts.
Cross member bolts (4) M8 x 30 mm bolts. And (4) fender washers
Hope these measurements help you out. If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
Hello
Cross member bolts (4) M8 x 30 mm bolts. And (4) fender washersHope these measurements help you out. If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
