How bad is torque arm vibration?
I just installed an adjustable torque arm and i set it at -2 pinion angle seems okay i feel vibration but im not sure if its the road or the torque arm.
Its a rod end from umi its at -2 degrees as of now i took out the back seats so there is more road noise from that just wondering how loud the torque arm vibration would so I could pick it out.
As long as everything is torqued to spec. There shouldn't be that much road noise. But if you have your pinion angle happens to be off then you will get a vibration around 60-70 mph. And seeing how you are using a tunnel mounted arm you are going to feel/hear a little road noise due to the cross member being mounted right under the front seats. If you have any other questions feel free to give me a call. I am in the office M-F 8-4:30 EST. And I will be more than glad to explain some solutions over the phone so there is not confusion.
Thanks Again
Brad
Its a full length I forgot to add that sorry for the confusion. i drove it to school today and it did just fine nothing out of the ordinary, but then again i didnt get above 45mph. Im assuming if it was out of angle i would know right away?
