Size of tunnel brace bolts
Old 01-09-2004, 09:44 AM
SloppyRob's Avatar
Default Size of tunnel brace bolts
I need to find some longer bolts for the tunnel brace. The reason being I have removed the tunnel brace, put KB DD subframe connectors on, and am adding a driveshaft loop (All of which attaches to the tunnel brace mounts. The stock bolts are just not quite long enough. Anyone know the bolt size and dimensions etc.
Old 01-09-2004, 11:57 AM
DARK AGE 53's Avatar
8mm, you should be able to get longer ones from AutoZone, Advance Auto or a fastners place.
Al
