Who to buy shocks from
I have decided to replace the front shocks on my car, and I was hopin someone could be of help, I am looking to say around the 200 dollar mark and only need the front pair. My car is lowered on the Eibach Sportlines and when I put the shocks on there I couldnt afford more than stock replacements. I know the custom shocks are really expensive so would I be better just replacing with stock replacements or would something like KYB AGBs be an upgrade that would work. Thanks for your time.
what do you want? ride quality? handling? drag performance?
if you're lowered with a higher spring rate (which you should/do have) you need a shock that can handle the higher rate. throw Qa1's out the window right there unless you're going back to a softer spring and want drag only performance with stockish like handling. i'd look at KYB's since you're on a pretty tight budget, otherwise look through the classifieds for some used SLP bilsteins or something.
I'm mainly looking for ride quality, as the car is basically stock and doesnt see the track very much. Thanks for all your help. I found the KYB AGXs on summit for 100 a piece does any sponsor have a better deal?
Well i know where you are coming from as I did the same thing bout some gabriels from vato zone and three months later one of them blew out. good thing they are giving me warranty money back. I ended up gettin a set of new bilsteins for 370 shipped which I think was a pretty good deal. KYB are almost close to what a bilstein will run you might as well get the good part if you're gonna tear into it.
