suspension upgrade
suspension upgrade
Just wondering what some of you guys thought of the edelbrock pro touring suspension package. I'm not looking for a drag race setup, but the ability to handle the road and take a turn well. I know there are many options, and I have been doing my own research on this, but I am interested in the opinions of those who have gone through similar upgrades.
http://www.edelbrock.com/automotive_...ion/kits.shtml
Search around some more and you will notice that the guys into handling run very similar setups when it comes to spring rates, swaybars and shocks.
The Eldebrock IAS is a pretty good kit by it's self, this pro touring kit has all the supporting mods with it...cool
Or Sam Strano sells the Eldebrock IAS kit and all the same supporting mods but you'd get hollow sways vs solid bars + some of the parts in that pro kit you may or may not need like the SFC & torque arm. I'd give Sam a call and talk about your goals and he may be able to get you where you want to be with less parts and less $$.
good to know. I think I have a direction on which way to go now. I just have to make sure the components I select work well together, which was one reason for considering the edelbrock kit, but I may not need everything in it. I may get springs from Strano. Maybe the Watts link kit, but money will be a big factor there...
Hello
I noticed that are you looking into upgrading your suspension. And I just wanted to leave you know that UMI Performance has a wide variety of suspension parts that I am sure with meet your needs. And like mentioned above! If you are going to get a set of Konis then I would highly suggest looking into a set of Sam's Springs. Besides he carries our parts as well. And consider it a on stop shop. Below is a link to show you what all UMI Performance has to offer
http://www.umiperformance.com/catalo...slk9gmff3d6aq7
If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
While the Eldebrock may not be THE best kit I thinks it's an under rated kit also. You can get the IAS kit for less than a set of Koni SA's and use your stock rear spring on the heater hose mod for a good .75" drop. Use UMI for LCA's & adj PHB and maybe relo brackets if you develope some wheel hop. If $$ are an issue Watts links aren't cheap and may need an adj rear sway bar.
A friend of mine had the IAS kit on his firebird and loved it.
I think I 'll go with the Edelbrock IAS shocks, coilover's front. Rear, the heater hose mod is tempting, just about the amount of drop I want back there. I'll think about it. I'll likely get some supporting components from UMI. It should hangle pretty well when it's all done.
