wheel spin fix
315/35/17 in back. Im getting BMR lca relocation brackets, BMR lca's, strut tower brace, and panhard rod.. What exactly does the pan hard do and with my larger tires do I need one.. Thanks.
Aside from the obvious handling/stability benefits, an adjustable panhard rod is also useful for centering the rear end under the body. I don't think it would do much for wheelspin- but it would for handling.
A good torque arm would help assist with reducing wheelspin (by aiding weight transfer).
As far as traction goes, you either have too much air pressure, the tires and pavement are too cold to handle the power or you need to control your right foot.
(and if you switch to LT's- the conversion is only $100 or so)
(I'd definately suggest Spohn as well)
