whats size sway bar do I have....in mm....
Also, what about the bushings that are on each end of the sway bar.....where should I buy these, what brand? AC Delco's from www.rockauto.com???
Moog's are $5.50 each...how can they be that damn cheap.
Also...are the front end bushing links the same exact ones for the rear sway bar?
I might as well change those too, there also 12 years old.
Oh...when I put in the bushingsand end links....do I just need the weight of the car off the tires? So jack stands under the frame. Then just unbolt everything and put the new stuff in?
moog makes poly ones and rubber ones, so whichever you prefer. you can just go to your local autoparts store and ask for them, then you don't have to worry about ordering the wrong stuff (hopefully)
to install the endlinks you'll definitely need the suspension loaded, otherwise the lower a-arms and rear end are down too far to get the nut onto the threads. ramps would be your best bet.
Then for the rears, I can jack the back up, then lower each wheel onto the ramps and take everything apart......???
nothing will be loaded. Remove the end links then bushings, install new bushings and thread bolts in enough to keep the bar secure but loose. Install the end links and tighten them to 15ft-lbs, then tighten the bushing bolts. Make sure you get the end links as close to vertical as possible. The end links mounting points should be parallel to each other, this may require you to move the bar from side to side and go back and forth between tightening the bushing bolts and end links.
Be carefull not to over tighten the endlinks the bushings should not be squished. Maybe a little locktite on the top nut
BTW...when I get home this week I'm installing new upper and lower a-arms, tie-rod ends (outers), and new front shocks. Does it matter if do the sway bar bushings and end-links AFTER the front end-alignment? Or should do it BEFORE the alignment with everything else? Or does it make no difference?
my question is...with all those mods in your sig, why not just buy some UMI or Strano bars? They will come with new bushings and end links and pretty much complete your suspension setup.
http://www.stranoparts.com/partdetai...=129&ModelID=8
But my car is just a street car. New bushings and end links are like $40.00 total.
How much difference will I really feel with this car being just a street car if I spent the money on that kit?
those will make a pretty significant improvement, I would get those if I were you. Also, its funny when people say "I just have a street car" when they are running huge engine with cams, etc and are pushing almost 500hp. It will definitely make the car more fun to drive. At minimum some people run the 35mm front bar with the stock 19mm rear bar, so if you wanted, just get the UMI front and some rear poly bushings and end links. There was a day when the ST 35mm solid bar was only $125 which made it a great buy especially since it can with bushings and end links but those are about $173 now. The front UMI bar can be had for $156.74 shipped http://www.byunspeed.com/product_inf...843dd6f4d10285 and the rear bar is another $151.99. http://www.byunspeed.com/index.php?c...843dd6f4d10285
