Fays 2 Watts Link
Old 07-22-2010, 09:31 PM
vatechguy3's Avatar
Default Fays 2 Watts Link
So, I finally got around to ordering a watts link for my car (thanks sam!).
plan to do the install next weekend.
from what i've read on here the two problems that i might run into are:
1) the u-bolts for the sway bar might be too short when the spacer is added.
2) the tabs for the brake lines get in the way of the axle clamps.
i talked to jim and fays2 and he said for problem one that he has the part number for a different set of u-bolts to use. he is going to email me the part number and where to get them from.
as for problem 2) i'm looking for input from people who have done the install.
what did you do about the brake tabs and how did you route the brake lines?
thanks
tony
Old 07-22-2010, 10:30 PM
wrencher
wrencher's Avatar
You have to remove the brake tabs from the housing. Grind them down smooth.
get some thick tie straps & tie the brake lines down to the housing with those.
There is not many options for the lines to clear the axle tube clamps.
I did have to go with a custom mounting set up for my rear sway, those new U-bolts are the ticket.
Old 07-22-2010, 11:31 PM
libertyforall1776's Avatar
So what made you go for the Watts Link? Just curious...
For $650+ shouldn't the longer U-bolts be included? I'm just sayin'.
Old 07-23-2010, 12:32 PM
99Bluz28's Avatar
Test fit the Watts frame assembly to see if you'll have any muffler clearance issues, and buy a digital level(not a laser level) at your local hardware store, but the most important thing is to take you time with the install.
Old 07-23-2010, 02:39 PM
beaSSt's Avatar
I spent more time getting the brake line tabs off then anything else. The install is pretty straight forward.
I have the SLP dual-dual exhaust setup so I ended up reversing the propeller nut / bolt as I could not get the bolt in from the muffler side.
Take your time, use locktite where appropriate, torque everything correctly. I also marked every bolt with a magic marker at the 3 o'clock position. Used a red marker on the bolts so it shows clearly. If anything shifts it's easy to see.
I'm in my second summer with the link and have never had a problem and nothing has come loose.
Old 07-23-2010, 02:41 PM
beaSSt's Avatar
One more thing -- I ended up making a 1" sway bar spacer out of square tube to move my SLP swaybar away from the axle mounts for the link. Put it between the axle mount and the sway bar bracket.
The spacers with longer U bolts did the trick, gave me lots of clearance between the link and the bar.
Old 07-23-2010, 03:01 PM
Old Blue's Avatar
Everyone is telling you right, get the longer "U" bolts and grind the taps off. Heres mine installed, make sure you get the arms level. This is not a Fays 2 but close:
Good lucj with the install, take your time, shouldn't be a big deal at all!!
Bill
Old 07-23-2010, 03:33 PM
^which one is yours then?
Old 07-24-2010, 10:01 AM
tillery's Avatar
Mine fits with the GMMG exhaust with a 12 bolt with the Moser cover. Will see about getting pics posted later.
Old 07-26-2010, 06:53 AM
Old Blue's Avatar
^^I made that one!!!
Bill
Old 07-26-2010, 07:41 PM
^ Nice work. What is it, a one-off then?
Old 07-26-2010, 07:44 PM
merim123's Avatar
I've done some reading on this and what it's supposed to do, can you guys comment on how it changes the car driving it on the street?
Old 07-27-2010, 07:26 AM
Old Blue's Avatar
^^^I made two of them !!
I don't know for sure if I can feel the change in handling or not???
It looks way cool tho
Bill
Old 07-27-2010, 01:51 PM
BMR Tech's Avatar
Bill
Nice job on the Watts link.....
Try adjusting the center pivot down to help adjust your roll center it looks like right now it pretty close to stock.
This adjustment should make noticeable differences in the handling characteristics of the car.
Dead on about the way cool looking part
Old 07-27-2010, 02:04 PM
merim123's Avatar
BMR - you guys planning on making these setups?
Old 07-27-2010, 02:39 PM
BMR Tech's Avatar
We have a lot of new things in the works right now with the 5 gen but don't worry we aren't done with the 4th gen yet
Old 07-27-2010, 04:25 PM
merim123's Avatar
looking over the pics above, it sits lower than the bottom of the rear? won't this cause ground clearance problem on the street?
Old 07-27-2010, 05:37 PM
99Bluz28's Avatar
You shouldn't have any ground clearance issues, I've never any to date even with my car being rather low.
Old 07-27-2010, 06:50 PM
merim123's Avatar
that's a better picture for ground clearance, thanks!
Old 07-28-2010, 12:40 AM
96silverram's Avatar
I have this item and have been putting it off (too lazy in the summer heat ) Can someone tell me where I should start with the center pivot bolt. I think there are 5 or 7 slots ? Do you start in the middle or do you suggest a different suspension setting. The car is loaded with BMR & Strano parts on the suspension. So, I would like a setting that will show the handling upgrades for the street mostly. I'm open to suggestion.
PS: Yes, the part is way cool !
Quick Reply: Fays 2 Watts Link
