Umi double adj phb question???
I got one coming should be here Thursday, my question is how many inchs can I shift the rear end to the left? My cars right wheel seems to stick out a little more then my driver side so I'm just hoping it will fix this. I need adlest to shift it 2 3 inchs to the left.
Yes 2-3 inches is a lot and like Lee mentioned something would have to be out of whack if this is correct.
Stand a level up (or straight edge if you don't have a level this length) next to the rear fender well and measure from the level in to the center of the wheel. Do this on both sides and see what the difference is. If the difference is a 1/2" you only need to move the rear end 1/4" to center it.
Try that and let us know your results. The double adjustable panhard bar can be lengthened/shortened 1" safely.. this is more than needed.
Hope that helps,
Ryan
Hope that helps,
Ryan
ryan@umiperformance.com
Thanks,
Ryan
