People with Hotchkis springs....
Old 01-21-2004, 10:29 PM
BADA BING BADA BOOM!!!!!!
Richie Carbone's Avatar
Default People with Hotchkis springs....
Did you use the stock rear spring isolators or just wrap some 5/8 heater hose around the top coil?
Thanks!
Old 01-22-2004, 12:31 PM
ulySSes's Avatar
Stock rear spring isolators here. No problems.
Old 01-22-2004, 06:05 PM
Thanks!
Old 01-22-2004, 08:10 PM
1STGEN68-2000SS's Avatar
You need to use the top isolators if you don't the car will set too low in the rear. Also make sure that you put them in the same way that they came out at the top it will help the spring set where it is suppose to.Put a mark on the isolator and the cup that it sits in.
Alan
Old 01-23-2004, 01:09 AM
Bad Blu Formula's Avatar
Must be a Camaro thing. My big a$$ed formula need to have the insulators removed.
Old 01-23-2004, 12:31 PM
ulySSes's Avatar
Originally Posted by Richie Carbone
Thanks!
No problem. Just a tip. Whatever you do, do not use the spring compressor that you rent from Autozone, etc... It'll be a nightmare!!
Good luck, you'll love those springs.
Quick Reply: People with Hotchkis springs....
