Maybe a dumb question about line locks
I was just wondering how a line lock really works. I know the basic concept is to keep the front wheels locked while the rear spin free by keeping line pressure on the front breaks after you let your food off of the brake pedal.
Can a line lock be setup to NOT hold pressure on the front brakes, but rather block pressure to the rear brakes? What I’m thinking is I can turn the lock on, start my burn out and then stomp on my brakes to prevent me from rolling into the start line (no one likes it at the drag strip when a street car roles into the start line doing it’s burn out). If I can configure the line lock to “block” pressure to the rear brakes, then I won’t be killing the rear brakes while I heat my tires.
Anyone try this?
Anyone try this?
Ya, I know that's the way it works by default, but a little re-engineering may allow me to change what it does. I know I’ll have to reconfigure how it’s inserted into the brake system. I just don’t know how the lock solenoids work. Will they effectively block pressure as easily as they hold pressure on a line.
Unless you have a very short distance between the water box and start line, there is no reason you should roll through the lights doing a burnout.. I do a good 5 second burnout, release the linelock, roll out of the box and let off the gas.. I'm still a long ways from the start line after the burnout.. Are you doing too long of a burnout maybe?
Yes, I recognize this but I want the freedom to start my burn as I normally do and then stomp on my brakes about half way to the start line. This puts the least amount of strain on my clutch since I’m not forcing it to start a burn on a sticky surface and I’m not stuck sitting in the water box (this also they complain about). All I’m looking to accomplish is the ability to hit my brakes but only engage my fronts. I turn the lock off and my back to braking like normal.
Pretty sure you can put the line lock on the rear line instead of front. Engage the lock, then step on brakes = no rear brakes. Don't some of the automatic cars have it set up that way so they can modulate how much their car moves while doing burnouts?
I don't know about the autos. I've just never heard of anyone trying it, but it makes perfect since to me. I think I may just buy a kit and give it a test. worst case is i have a line lock i have to use the traditional way. I figure I may be able to come up with some test with some spare parts to test it before I install it on my car.
I understand exactly what you are trying to do. You are trying to limit your roll out and not necessarily sit in one place without burning your rear brake pads up.
You can use a traditional line lock solonoid with the proper fittings to install it on the rear line. by the way the rear brake tube size on my 96 is 1/4".
Once you decide where you are wanting to place it u can cut and flare your lines as needed but instead of installing the Line Lock in a traditional manner you are going to put it in backwards against the normal flow that way when you activate it you can press the brakes as hard or soft you want and fluid will not be getting to the rear calipers. Then you will have roll control by foot. Makes for cool burnouts.
OP my son did this on his Y2K truck 9 years ago with no problems as today,(other than eating up a lot of tires ) the point which he likes is going to a street cruise and fethering the brakes enabling him to do a 2-3 block burnout
you know kids will be kids, ................but a'nt it fun
Johnny
Johnny
Thanks
