Panhard bar and LCA Install
i just got my panhard bar and lower control arms and got some time in the morning to install them should i be doing this by myself how hard is the install and is there any specific torque order and lbs i should be going by
thank you for that tip i see in the directions that came with the stuff it said 1 at a time and i read a thread where it said u might have to jack up the differential to move the angle points any possible suggestions upon where to place the jack stands
I normally stick the jack stands under the sway bar bushings for the rear axle.
Also, if your LCAs and PHR are adjustable, the best way to start, as far as length, is to take the stock part, slide the bolts through both bushings, then adjust the ends of the adjustable piece until it fits down on the bolts on top of the stock part - that way, you've got a confirmed length that works when you put the replacement part in, so you're starting any later adjustments from the stock axle location.
its very easy and quick, takes about 45min to do lca's/phb. just put the jack stands on the frame in front of the rear, keep the jack on the rear to move it up/down to help with fitment. thats what i did
^Yep, I just swapped out my rear and somehow I totally forgot that you're supposed to torque down the panhard and LCA bolts while the suspension is under load, not while it's hanging down on the rack. Otherwise the bushings will not be in the correct positions in the brackets. Then when you drop the car the bushings bind, causing clunking and creaking. I had to crawl underneath the car and do them over again.
