Anyone ever tried making LCA relocation brakets
1 Post
The things look really simple to make and i might when i have some free time at work, anyone done it before? Cant be hard at all...
bending 3/16 stock and putting in parallel/located holes,you can't beat the value of purchasing weld in/bolt in LCA relocation brackets.
but I did make/fab extensions.
as the angle of the LCA increased,so did traction. only flaw in the design is getting a flat tire and the extension would hit pavement.
first year ls1. i think you should probly get a new set. your hole didnt follow the curve of the LCA. if you lookat all relo brackets. the top hole and bottom are not in line. this is so a stock LCA keeps the rear end were it was. your would movfe it way forward
